RCU Forums - View Single Post - Chung-Yang
Thread: Chung-Yang
Old 09-08-2008 | 09:32 PM
captinjohn
Default RE: Chung-Yang
Some reading I copied and pasted.....refers to the CY23RC engine as the "Fuelie". The CY23RC is the stock engine for the Baja 5b - HPI part # 15401.
Chung Yang CY23RC engine (32mm bore, 28mm stroke - 22.5cc) with Walbro WT-668 carb. 2.5 Horsepower. Similar design to the Zenoah G230RC - 4 transfer port 32mm cylinder, single ring piston, double sided finned flywheel, and HP exhaust canister. Ready to bolt-on. All parts are interchangeable with the Zenoah G230RC. Engine is available with or without inner clutch. Engine requires 91 octane (using the R+M/2 octane rating method) or higher fuel, mixed 25:1 with 2-cycle oil (5 ounces per gallon). Engine is available in complete form, or you can choose to purchase the engine without the carb assembly and airfilter if you already have these parts and don't need them.
Available in factory black finish or with chrome shroud, fancover, etc pre-installed.
For scooters: Top speed for this engine with a stock .625 size drive spindle is approx 26 mph. Larger spindles will be faster. Fits Sport, Liquimatic, Bigfoot, X-ped, Super X-ped, Super Bigfoot, Go-Quad, Super Go-Quad, GSR26R, and Homebuilders Kit. Also fits GSR25, GSR26R, GSR29R, Quad 25, and Quad 30 when used together with 54mm clutch assembly.
For R/C: Fits a wide variety of 1:5 and 1:6 R/C cars, planes, boats, and helicopters. Same mounting dimensions as Zenoah G230RC / G260RC.
