RE: Byron Wedell Williams Racer Build
Radio installation calls for fitting the nylon exit guides then gluing to the blue nyrod tubes. I epoxied mine in place and later found that they didn't line up as well as they should have and were binding. I had to bend the 2-56 threaded rod some as well as remove some of the guide with the Dremmel to eliminate bindng. Recommend fitting everything and adjust the nyrod exit guide so it lines up better before gluing. The Rudder nyrods do cross in the fuse and need to be supported. 1/4 hardwood stock is used drilled in center for a dowel the tubes go around. The support is tack glued then fiberglassed in place. The black circles were drawn on the outside of the fuse with a sharpie marker to help me keep the position while gluing. Zip ties used to hold the tubes together. The tubes and yellow nyrods were cut to length per instructions and fitted with 2-56 threaded rod and ball clevises for the rudder and the threaded end of a 2-56 pushrod soldered to a clevis at the servo end.
Pete
