RE: Elevator Question?
The big knock with the Top Flite Gold Edition kits is the weight. Adding weight to the rear of the plane will most likely mean adding weight to the front end to balance the plane. The golden rule is one ounce on the rear equals 4 ounces on the nose. Just build it as per plans, you will be just fine. Good Luck, Dave
