RCU Forums - View Single Post - Can you start engine with a drill?
Old 09-09-2008 | 08:29 AM
kid chuckles
Default RE: Can you start engine with a drill?
For my starter I use a 200amp charger for vehicles. This is at home at the field I ran heavy guage wire from my battery to the back of my truck. Drilled two holes and inserted bolts with wing nuts. I hook my starter up straight to the bolts. You can extend the wire from your starter if you need longer lentghs. This works better and your starter has more power than the small 12V that come in the toter boxes. I have them also for when I just can't use my truck. The drill deal will work in a pinch but man a starter is not much more than a drill. I understand most folks have the drill though.
