RCU Forums - View Single Post - Seamaster 40F
Old 09-09-2008 | 09:31 AM
  #39
ekfinch
Default RE: Seamaster 40F
Wow, that is great. I may shift completely to EF at this rate. I still like the nitro except for the hassle of the fuel, starters, etc., but from the looks of this you can just about run any of the planes I have Electric. Very amazing. This is really good stuff. Thanks for all your help. I will let you know when I do my first flight. I also have a eflite Taylorcraft 450 that should be here tomorrow. It looks like a great little plane and everything I have read is very positive. I plan on using it as EF. I fly a little Super Cub off the boat right now. Very relaxed and lazy. It is sometimes a challenge to trim out and can be tricky in the wind, but it has taught me to fly with the wing instead of raw power. I also fly an Avistar at the field. Trained on it. Bit tricky at first with an OS46AX on it, but it does a lot more than the normal trainer.
Thanks again. These are all great sites.
Keith
