RE: x9303 or DX7 can you feel the diffrence on sticks
You can't feel the difference in the Sticks. The higher end radio's are more for programing and mixing and such. They are kinda overkill for foamy type planes. If your going to get into 100 size 3D planes or more then you will be better off with the more programable. But then again the DX 7 does have alot of programing that can be done also. Don't spend the money unless your going big and bad. The 7 will do anything that you can want to do with a foamy and actually a 100 size also. The bigger gasser's are when the 9303 shines.
