RE: E-flight AT-6 TEXAN?
Mine flies great! But, the monocoat on the top of plane bubbled and wrinkled severly in the hot California sun(about 100deg F)> Came out of box OK,just wrinkled in the heat.
Takeoffs are smooth,flight is VERY smooth and easy to control...........landings,well lets just say I need a new canopy(nosed over both times)otherwise perfect.
The suggested power 25 motor is just fine for this plane.....plenty of zip in flyby's.Actually will tip the plane if you "gun it" too fast,so be careful on throttle.
