RCU Forums - View Single Post - It's the little things...
Old 09-13-2008 | 05:39 AM
jack1933
Default RE: It's the little things...
Hello Point, I would like to know if the switch in your post is a knife type or the rub two contacts together type, sorry for this explanation, maybe , "the other type" would be better, if it is the "other type", then I would not use it at all, vibration will cause one problems, also the bat handle types are not acceptable for the same reason, they are ok for transmitters, but they are not subject to vibration. This is from actual experience.
