RE: Need Mechanical Retract Installation Diagrams
if it isa built up wing you just mount either rails or a retract plate out of ply wood and p;osition it where the normal gear would be making sure that when extended the axle is under the l.e for conventional gear.the ply plate type mount used in foam wings is the esiest to install and will cause less distortion.
