RE: YS110 tuning question
OK, When I assembled the plane I did not drill a hole for the regulator screw. I drilled a hole and sealed the hole with CA. I used a lot of CA to make sure it was good and sealed. Well I had CA run into the threads of the regulator screw. Now it ran awfull and I couldn't get it running half way decent.
So I had to pull the engine and remove the screw and housing. I got all that cleaned out and got the engine remounted. Took it out this afternoon. Got the high end dialed in. OK idle, great transition, no loading up. So far so good. I now have a new plug in it and about one gallon. I'll play with it more as I get more fuel through it.
Thanks again, MikeB
