ORIGINAL: jaka
Hi!
Never use any pins! I have door to build on but have it covered with a glass plate on top of it! All formers are spot glued with Ca glue onto the glass and when I want to remove everything I just take a woodworking chisel and pray away the glue.
I have a hard time getting my head around the idea of building on a plate of glass. I use pins not just to pin thing "down" but also to press other parts down on other parts and to wedge them together and a thousand other things. Still, I'd like to hear from people who build on glass and how they do different things.
My building surface consists of a sheet of dense particle board (about 1" thick) covered with a sheet of blue foam, which in turn is covered with a sheet of smooth corrugated plastic. It's not ideal what it's what's what was available.
I also can't imagine myself building on one of those magnetic building tables. I'd have to entirely rethink how I do almost every building task.
