U Can Do firewall WARNING !!!!!
I had the same problem with my UCANDO3D. After a couple of months of flying the firewall pulled out. Luckily I noticed it on the ground.
I have had this problem with all ARF's, however. Every ARF I have seen has the fire wall hot glued in. When you buy an ARF you have to plan on replacing the firewall and landing gear block.
