ORIGINAL: DAN REISS
Hi Pete, How did you get the elevator pushods to cross without making contact. It looks like the elevator servos are mounted to the same surface. Did you have one of the pushrods with the connector ends up and the other down? Dan.
Dan,
The right exit is slightly lower than the left. There are outlines for the exit guides marked into the fiberglass where to locate them. The pushrods do barely touch and I'm going to glue a piece of felt at the crossover to prevent any chaffing.
Pete
