RCU Forums - View Single Post - Heck of a mess!!!
Old 09-15-2008 | 06:58 AM
goirish's Avatar
goirish
Default RE: Heck of a mess!!!
ORIGINAL: yel914
Try using plastic sheeting from the hardware store, 2-3 mil thickness, as a plan protector. It's cheaper and is easier to peel away from parts that get glued to it. Also, if CA is too much for you, try yellow woodworkers glue, like Titebond. Gorilla glue has it's uses, but not on most parts of model airplanes. Good luck
The gorilla glue that I use is the wood glue, looks like titebond only it dries more clear. Grabs fast. This is not the glue that expands like I would use for robart hinge points. I normally don't use CA but did this time and it will probably be the last time.
