RE: Protech PT-80 Turbine ??
Hi Tim
I doubt an injector has fallen off. It's more likely to be blocked. Just tear it apart, I'm sure you can sort it. Once the manifold is out, connect your gas filler bottle up to it and light the gas that comes out of the needles. You are looking for an even height of flame that varies by the same amount as you turn the gas up and down.
Jason
