RCU Forums - View Single Post - cx-2 clockwise issue
Old 09-15-2008 | 02:39 PM
Custnam's Avatar
Custnam
Default RE: cx-2 clockwise issue
Soloboss, I agree completely. I have mine so well balanced out now, that I can fly it in my driveway if theirs no wind. And I could sit down under it like it was a fan and enjoy with cooling. Now like you said this only works outside in my case. (Since I have no indoor areas to fly other than my garage) But even in my garage if I get it high enough and out of the way of anything that can interfere it hovers perfectly. And the TBE is gone also now. It just took a good studying of the blades and picking the best out of the bunch I have. The guy that I got this from sent me a set of aftermarket blades that say cx-2 on them, but are a different configuration. They have only one screw hole on the top. So I need another aftermarket part for these to work. I already bought the aluminum bulkheads and swashpplate, so Im thinking if I wanted to run the aftermarket blades that Id have to get some more parts that would defete the purpose of why I bought the eflite alum parts. Whats your experience on the different blades? Are they any better? Stronger or better performance? Or should I just stick to blades that will fit with the way I have it set up now? Thanks alot!
Ok, I see how they work, they actually dont replace the bulkhead, they just make the blades a 2 piece instead of just one. So I could just get the pieces that go from the bulkhead to the blades, and that would allow me to use the other set of blades I have? So Ill ask the same question, Is it worth switching to this? Or just keep running the one piece blades? Thanks again
ID:	1034024   Click image for larger version
ID:	1034025   Click image for larger version
