RE: Extra 300S vs Extra 260
The 300S is considered a low wing.
The full scale 260 is a much better aerobat than the 300S. But that doesn't help you a bit, because the models are not exact scale. You are going to have to find someone who has flown both of the specific models you mentioned to give you an accurate comparison.
Failing that, you should probably pick the one with the lowest wing loading.
Jim
