RCU Forums - View Single Post - Volcano Help??
Old 09-15-2008 | 08:46 PM
AllAboutFunHobbies's Avatar
AllAboutFunHobbies
Default RE: Volcano Help??
You need to set it back to factory settigns and start from there. You set the HSP 2.5 to 3 turns out from seat. You set the LSP flush with the collar. Set a 1mm gap for the idle screw about the size of the tip of a tooth pick. Then you can start tuning. WHen the weather changes you MUST re-tune the engine.
