RCU Forums - View Single Post - CPLR new plane OSMOSE
Old 09-17-2008 | 07:54 AM
  #270
apereira's Avatar
apereira
Default RE: CPLR new plane OSMOSE
Remember the gear is swept back, and with only two bolts, the gear will most likely crack in the middle due to uneven forces applied to not supported edges, and if for some reason you happen to have a rough landing or run into tall grass,it will for surecause damage, try to flex the gear by hand to verify, just keep it in mind.
Regards
