RE: Good base for building
I got the idea to build on glass from the Dave Platt tapes. CA to the glass or use weights to hold things down. I still use pins to hold pieces together. I also use a small balsa board if I need to pin pieces down. Glass is a wonderful surface to build on. Everything can be scrapped off.
