ORIGINAL: Salty25
3. Should I cut out the bass I used for aileron braces and replace with balsa as the instructions said to use or just leave it.
How much basswood did you use? If it is just the diagonal braces I would not change it.
I built the Uproar and have an ASP 61 two stroke on it. It is a nice combination. I've seen them with various .75s and even a 1.20AX and it seems like a great plane no matter what you bolt up front. I recently broke the landing gear mount on mine, and twisted the gear up like a pretzel. My replacement gear is the Dubro plastic/glass unit. It's taller than the stock gear. If you go with a big engine it will add prop clearance.
