ORIGINAL: carrellh
ORIGINAL: Salty25
3. Should I cut out the bass I used for aileron braces and replace with balsa as the instructions said to use or just leave it.
How much basswood did you use? If it is just the diagonal braces I would not change it.
I put the basswood in as the diagonal braces. I only did it on one before I realized my mistake. The second one is sitting there without the braces put in yet.
I bought this kit with the intentions of putting a Magnum .75 up front. Now I have the .75 and a .90 with no home so I could use either one of them.
Like I said this is only my second kit build, I have done many ARFS. My first kit was a Shrike, the small one. That one went together very well; but it was done a few years ago.
