RE: CDI units for $25 bucks??
Hello, I just purchased 3 of these. Only one seems to work when passing a magnet over the sensor. Will have to check the others a bit more.
Duayne, the hall sensor wiring polarity looks to be different from the standard Rcexl hall sensor with the positive and negative swapped around.
The early (V1?) Rcexl ignitions were like this also. This maybe your problem?
Regards
