CDI units for $25 bucks??
Duayne, it would seem like if you paid them for the cut Hall sensor lead...($3)... that should take care of the runied part. But they should have a 1 year gaurantee on ignition box! Most places will not do anything...if you give up to easy. Hope they will do it right for you. Capt,n
ORIGINAL: aero nut
Like I said guys I have the Rcexcel with the sensor!!!! guaranteed why botter with no customer service uhhh!
I have a big gasser plane I've been slowly rebuilding, the radio has been replaced (didn't have one) and all servo's are good to go.. my problem is with the ignition system. The plane has a cdi box in it with 3 wires on it, one goes to on/off switch but I have no idea where the other 2 wires are supposed to go. I'm assuming at least 1 must go to a power source to fire up the box but am unsure. Do I need a seperate power supply other than the radio batt? I'm sure I haven't given enough info but that's pretty well all I know
Any info would be helpful, thanks...Chris
#32
dear sir
for this CDI.XYZ brand...we have our team to do this CDI..do many times testing...it performance good...if you or your friends have ever use this CDI .you will know our quality....
thanks.
thanks.
