RCU Forums - View Single Post - Nitro models pusher Bobcat?
Old 09-20-2008 | 09:14 PM
  #3476
opjose's Avatar
opjose
Default RE: Nitro models pusher Bobcat?
ORIGINAL: Xairflyer
Ailerons reflexed up would keep the model on the ground not make it takeoff better, we do them like this on the 3D models and the minute you put them on the aeroplane falls like a stone.
That's exactly what it does, but in some cases it actually helps people with their Bobcats!!!?!
Why????
People who have not set the angle of attack properly experience that long run-up and sudden vertical takeoff problem...
The spoilerons kill some of the lift permitting a more gradual rise off the ground... but this is NOT a good solution to the sudden departures... instead the original problem should be dealt with... the AOA should be fixed so that the plane's nose is a bit higher...
