Super8 5 Point mixing, how do you link the trim????
I want to use the 5 point mix on my Futaba Super 8 to program my 2 tail mounted elevator servos. The 5 point mix will give me 5 points of control over the travel of the servo to compensate for any differential (mechanical or in the servo). But there is no trim link on the 5 point mixers (mix 6 and 7) like there are in the standard mixers (mix 1-4). Kinda kills the idea because only my master servo moves with trim). Is the trim link hidden somewhere, or there a work around using a normal mixer in conjunction?
Thanks!
