RCU Forums - View Single Post - Should I buy it?
Old 09-21-2008 | 08:49 PM
Charlie P.'s Avatar
Charlie P.
Default RE: Should I buy it?
ORIGINAL: fly boy2
What is a considered giant scale, is it over a certain engine size or wingspan?
From the IMAA website
What is Large or Giant Scale?
The concept of large or giant scale is generally considered to apply to radio controlled model aircraft with minimum wingspans of eighty (80) inches for monoplanes and sixty (60) inches for multi-wing aircraft. Ducted Fan and Turbine aircraft with one hundred forty (140) inches combined length and width, measured from wing tip to wing tip at the widest point perpendicular to the fuselage and added to the length of the fuselage, excluding any protrusions. Autogyros with 50 inches for a single rotor, 80 inches for a dual rotor. Quarter (1/4) scale replica's or larger with proper documentation (minimum 3 view drawing of an actual person carrying aircraft) which do not fit the size requirements will be permitted. However, the concept does not encompass radio controlled model aircraft so large as to have the potential of carrying a human being.
