RCU Forums - View Single Post - Need Help
Thread: Need Help
Old 09-21-2008 | 10:23 PM
Xpress's Avatar
Xpress
Default RE: Need Help
Well, generally, you can look at these numbers to get what you want performance wise:
50 watts per lb. = low powered, slow scale flight
100 watt per lb. = spirited sporty performance
150+ watts per lb. = strong vertical performance, with hovering capability
Your original estimate of 300 watts would only fly a 3lb. plane max. I'm running nearly 500 watts in a plane that weighs ~33oz. with 2100 mah lipo, and it is a screamer vertical wise. 1/2 throttle hovers. 3/8 throttle cruising.
You are going to need around 700 or so watts to get 3D performance with that plane.
