RE: CG and throws for Sig SE?
Here are all of the factory specs
Set Up Specifications English Metric Directions
Elevator Low Rate 1 1/4 inch 32 mm Up and Down
High Rate 2 inch 51 mm Up and Down
Rudder Low Rate 1 7/8 inch 48 mm Right and Left
High Rate 2 inch 51 mm Right and Left
Ailerons Low Rate 1 inch 25 mm Up and Down
High Rate 2 1/4 inch 57 mm Up and Down
Center of Gravity 3 1/2 inch 89 mm From leading edge at root
Dihedral 0 degrees 0 degrees Per panel
Incidence + 0 degree wing, 0 degree stabilizer
Engine Offset 0 degree down, 0 degree right
