CG and throws for Sig SE?
CG is at the center of the wing joiner tube. Elevator low rate is 1 1/4" , 2" high rates. Ailerons are 1" low rates, 2" high rates.. Rudder is 1 7/8" low rates, 2 1/4" high rates. This plane can be a real hand full on high rates if you aren't prepared, but a real blast to fly. Good luck
IA
Here are all of the factory specs
Set Up Specifications English Metric Directions
Elevator Low Rate 1 1/4 inch 32 mm Up and Down
High Rate 2 inch 51 mm Up and Down
Rudder Low Rate 1 7/8 inch 48 mm Right and Left
High Rate 2 inch 51 mm Right and Left
Ailerons Low Rate 1 inch 25 mm Up and Down
High Rate 2 1/4 inch 57 mm Up and Down
Center of Gravity 3 1/2 inch 89 mm From leading edge at root
Dihedral 0 degrees 0 degrees Per panel
Incidence + 0 degree wing, 0 degree stabilizer
Engine Offset 0 degree down, 0 degree right
This is a nice thread to have... I bought an SE ARF at an auction last winter, but had no documentation.
I'm still hoping that Sig will make a 60 sized version of the SE.....
