RCU Forums - View Single Post - Kyosho Osmose 70, Sort of build thread (slow..)
Old 09-22-2008 | 10:34 AM
gpang788
Default RE: Kyosho Osmose 70, Sort of build thread (slow..)
ORIGINAL: Nigel201
Hi, thats my Osmose 70. I have used an OS55AX which fitted well in the cowl after a little trimming!! This kit is much better then the Oxy. The covering looks like it should stay on ok. The only things I have changed are the aileron links. I dont like the bends and plasitc keepers they supply. I have had three flights with the model so far and its superb! It locks into the manovers very well, rolls superb and spins fantastic. If the UK rain and wind ever stops I will go and fly it again....but that looks some time away at the moment.
Hi Nigel, have some questions for you..
1) Did you have any problems with the OS55AX running inverted?
2) Did u use a pump or regulator to ensure smooth running?
3) What glow plugs did u use??
4) Standard OS Muffler being used?
I have always wanted a pattern plane to go with my 55AX too but held back cos I was afraid of potential inverted running problems.
Care to share how you avoided these problems?
