RCU Forums - View Single Post - make Rivets in fiberglas surface?
Old 09-23-2008 | 06:45 PM
saramos's Avatar
saramos
Default RE: make Rivets in fiberglas surface?
The method I use for flush rivets is the heated brass tube in primer technique. I used the smallest brass tube I could get, and mounted in my trim iron. I also put a 90 degree bend in the tube to make it more comfortable. I prefer to mark off all the rivets first, making proper spacing adjustments so intersecting rivet lines properly meet. After burning them in, I lightly sand with 400 grit to knock off any rough edges.
Scott
ID:	1039737   Click image for larger version
