RE: Fly Eagle F-15 (1/9) Building Thread
Almost forgot, I riveted the bellmouth in place on the B-duct and installed the black belly pan under the engine. I mounted the L brackets for the fuel tanks but they are not pictured here. The aft end of the tanks fit tightly aginst the spar mount on the right side but there is just enough room for some foam rubber (thin) on the left side. I wish the right didn't fit so tight. Little worried it will rub a hole in the tank over time.
