RCU Forums - View Single Post - Omp Build Finished!!!!!!!!!!!!!!!!!!!!!
Old 05-25-2003 | 03:18 AM
joebob's Avatar
joebob
My Feedback: (14)
Default Re: OMP FF540P build
Originally posted by coyote
Haven't looked real close but is there room for an HS-81 mini servo mounted through the fuselage aft of the engine for the throttle? Will use HS-425's for primary controls. 270ma battery. Don't know which motor I'll hang up front.
TOP CAPS ROCK
It would be tough because of the tank position on the opposite side of the fuse. Now, if you had a tank that would fit in the wing, it would be no problem.
I used Hitec 225MGs all around on mine with an 81 for the throttle. These work great, and have as much torque as the standard ones while weighing 1/2 oz less. It saves at least an ounce in the tail, which makes it easier to balance with a lighter engine.
The more I fly mine, the more I like it. Still can't hover worth a darn, but I'm getting better. This plane flat spins great. I can almost get it to climb, and I'm sure if I knew what I was doing, it probably would. I love bringing it in for a landing at a very slow walking pace and let it just settle in with no rollout.
