RCU Forums - View Single Post - Nitro Edge 540T USA
Old 09-24-2008 | 06:34 PM
outdoorhunting
Default RE: Nitro Edge 540T USA
Hold the plane up to the light. You will see the opening in the fus for the servo. Just trim it out & then hook up your linkage like you normally would . If it's a Nitro plane the instructions do leave a lot to be desired. Make sure you go over all glue joints you can reach & give them a drop of CA Good Luck
