Nitro Edge 540T USA
NJ
I just started to put together my Edge 540T and I am finding out that the manual does not follow this plane at all times. I see that I was given an additional manual sheet but that only helped with the main wing. I need to know how I should handle putting in the servo and connecting the rudder. The manual shows that there is a small compartment under the fuselage near the tail. I do not see this compartment so I need to know what is the best way to connect this rudder?
FL
Hold the plane up to the light. You will see the opening in the fus for the servo. Just trim it out & then hook up your linkage like you normally would . If it's a Nitro plane the instructions do leave a lot to be desired. Make sure you go over all glue joints you can reach & give them a drop of CA Good Luck
