RCU Forums - View Single Post - Max input to Ram 500 Ecu ?
Old 03-18-2002 | 01:15 AM
Jackjet's Avatar
Jackjet
Default Ram 500 starting
[QUOTE]Originally posted by Helijet
Jack
Absolutely DO NOT use an 8.4 volt pack will blow components. A couple of tricks - spin up the engine with the electric starter then as it slows hit the start run button. That will take the current draw down some. We are now using 1250 SCR packs that are designed to tolerate a high current draw. Talk to Carlos at RAM with regards to your particular engine and needs. Should you require more info please do not hesitate to contact me through my website as well. Shop phone is also listed.
Regards
Dean Wichmann
RAM Marketing / Sales
Canada
[/QUOT
Dean,
thanks for the info-it just that the voltage of the cells just off the charger is over 9vdc and the Ecu seems to handle it ok-but that extra 1.35vdc may push it over the edge- so what I will do is parallel another 6 cell 5000mah pack for starting-just like jump starting a car....what do you think ?
Jackjet
