RCU Forums - View Single Post - MK Beetle Build
Old 09-25-2008 | 03:42 AM
  #60
T Brooks
Default RE: MK Beetle Build
Hello Everyone
It has been a while since I posted but there has been some progress.
The ribs have been adjusted to allow the push pull rods for the retracts through.
I have skinned the top surfaces using aliphatic glue and heaps of pins. In this kit the skin pieces are pre-glued together to form four complete sheets. I felt that this would make using CA very difficult to get a good reliable result. You may note that I filled in the square cutouts of the inner ribs with balsa (originally for servo wires). This sub-spar helped keep the correct shape in the fairly large open areas of the inner ribs.
Cheers
Tarquin
ID:	1040569   Click image for larger version
ID:	1040570   Click image for larger version
