RCU Forums - View Single Post - Venture Blade Tracking... HELP!!!
Old 05-24-2003 | 04:15 AM
R/C Xtreme
Default Venture Blade Tracking... HELP!!!
Just wanted to check with you guys to see if anyone is having the same frustrating problem that I am. I can not seem to keep the blades in track. In normal flight mode, my blade tracking is perfect... Switch to idle up... still fine... go into forward flight and tight turns in idle up and the tracking goes out. I can set the heli down, let the head spin down... switch to normal flight mode and hover... switch back to idle up and the tracking is fine again. This problem has been consistent with both wooden blades and now with perfectly balanced carbon blades. I have replaced the blade grips, blade grip bearings, and I have installed the KSJ thrust bearing kit. I have no idea what to try next. Any insight would be greatly appreciated.
Thanks... Mike
