RCU Forums - View Single Post - Robart Hinges. How to set to depth
Old 09-25-2008 | 08:39 AM
tmproff's Avatar
tmproff
Default RE: Robart Hinges. How to set to depth
I always use triangle stock between the TE of my wing and the control surface. This gives a large range of movement without creating a big gap. Where I am about to put the hinge point, I cut out a 1/4 inch section of the triangle stock that was glued to the TE, and then I drill a hole. This way, the large area of the hinge (where the pin is) seats inside the triangle stock.
ID:	1040695   Click image for larger version
