external battery
George,
Just wondering if a battery of the same size (7.2v) could be used externally so that you would not be putting all the load on the internal battery. Just increase the capacity of the external battery from 1250 mah to 2000 mah? Reading the other posts RAM recommends sticking with their batteries because the ECU could not handle the higher capacity but what about the starter motor?
Patrick.
