ORIGINAL: goirish
ORIGINAL: Mr67Stang
You might be able to find one in the field over which you were flying... real cheap
Sorry, could not resist.
Measure your bolt pattern in milimeters (center to center). Look at Tower Hobbies and see if there are any compatable mufflers.
That corn is 12' tall
It's very close to harvest time for corn.
Unfortunately, the way the harvest nowadays only means you absolutely won't be able to find it. Around here they harvest only the corn itself and everything else is blown back onto the ground.
