RE: New Monokote Technique
Ultra-cote should stick to the glass just fine for cutting. It's when you let it dry that the adhesive does not stick.
If I remember though ultra-cote is a lower temp covering. So I would imagine that after you let the windex dry, when you use the heat gun to remove the press-n-seal it should stick just with the heat alone. Or make sure you get it toasty before pulling.
Try it out and let us know.
And thank you for the kind words.
