RCU Forums - View Single Post - make Rivets in fiberglas surface?
Old 09-27-2008 | 01:51 PM
warrior2
Default RE: make Rivets in fiberglas surface?
Hey, Mach1! That plane looks great! How did you make the panel lines? I assume you drilled the "rivets" in the skin BEFORE priming?
Also, you mention "modified" drill bit. What size and type bit and how did you modify it?
I am building a Hostetler Cessna 150, and wnat to make some good panel line and rivet detall.
Joe
