RCU Forums - View Single Post - Painting problem
Old 09-27-2008 | 07:39 PM
Rudolph Hart's Avatar
Rudolph Hart
Default RE: Painting problem
Bob h is correct dick.Over here you get green or blue fineline made by 3m.The blue stuff is easier in tight corners.Make sure the surface and your hands are clean,if you get nervous you'll sweat.Try using your thumbnail to push the tape down properly when it is where you want it,your finger pads are quite soft and don't push tape edges down well.Good luck.
