ORIGINAL: RadarController
I have a can of Lawn Boy already. You broke it in on your plane? The plane I'm putting it on has no cowling.
Yes on the plane. Put some rope over the stabs and rudder.
craigteffe states one tank on the ground is enough which is true for most nitro engines, not for gasoline engines if you care about performance and a smooth running engine w/o troubles. My DL is running close to 7900rpm on an MTW RE2 pipe and Vess 22A (22x8). I'm almost through the first 3 gallons. Will shoot a video tomorrow, weather allowing.
