RE: Flat Foamie setup needed for Competition
Thanks for the response....My Aito look alike is weighing in at 217 grams the 360 Mah 3 cell 20C. I am using a electrifly 28-22-1380 100watt motor. I have a GWS rx and 10A Castle ESC. swinging a 9x4.7SF prop. I saw an article which showed the top winners equipment list. They seem to be at 180grams so I am in the ballpark. I copied their equipment as "if it is good for the goose......" I made sure that all surfaces are tight and no slop. I have them double tape hinged with the BlendDerm Tape. There is NO play in the servos to control surface links. Everything is Parallel and Perpendicular as it should be. I have 35% Expo and the throws are just as the book says on low rate and the high rate is a bit higher than the manual says. any problem with the above data?
Thanks again for the info.
Dan
