RCU Forums - View Single Post - Trouble building Hype 3D
Old 06-20-2003 | 02:38 PM
  #42
vease's Avatar
vease
Default Trouble building Hype 3D
That would certainly do it!!
The cables need to be tought. Not tight but tought. They shouldn't be so tight that they are stretched but they also shouldn't sag.
You must also make sure that the servo output is the same width as the horns of the moving surface otherwise the geometry is all wrong.
Good luck for Sunday and post how it goes
