RCU Forums - View Single Post - Rivets and decals
Old 05-26-2003 | 03:52 AM
pittsdriver's Avatar
pittsdriver
My Feedback: (7)
Default Rivets and decals
Try using laquer base polyurethane to lay the glass. Put a couple of coats of sanding sealer on the raw balsa, sand with 320 grit and a block then lay the glass using the poly. It dries in about an hour and two or three coats is plenty for a primer base. You can glass a whole airplane in a couple of evenings. Don
