RE: Need a Tuned pipe for a K&B
ifly,
Have you called the JHH shop? We'll get you setup with what you need (562)-467-0260. It sounds like you're missing the header pipe. There is a header that is used to attach the pipe to the engine. The header is attached to the tune pipe via the silicone coupler. This also helps set your tuned pipe length which is crucial to get optimum performance.
Chris
